My E90 320d LCi
Share pictures of your car with the rest of the club
Forum rules
Please ensure that you have resized your pictures, you can use photobucket or imageshack to host pictures.If you do not know how to do this please PM any of the mods who will be glad to assist you
To post pictures you will have to create a Photobucket or Imageshack account. Upload the pictures and then post the IMG code.
And the qualtiy is well better than our forum software doing it for you (which also isnt great, as it loads up the entire pic even tho it only shows a grainy version for the full size picture)
So do everyone a favour, and use this
Cornel
Re: My E90 320d LCi
Postby Cornel » Fri Sep 01, 2017 5:38 am
Thanks guys appreciate it
Cornel
Re: My E90 320d LCi
Postby Cornel » Mon Sep 04, 2017 5:48 am
Cleaned my car a bit.
Just love how it sits now. Still a few things that I need to sort out on it.
fly
Newbie
Re: My E90 320d LCi
Postby fly » Mon Sep 04, 2017 11:08 pm
Car is looking tops Cornel. Love the ride height on those wheels. What paint did you use to spray the gloss-black bits?
Sent from my Redmi 3S using Tapatalk
Cornel
Re: My E90 320d LCi
Postby Cornel » Tue Sep 05, 2017 6:00 am
fly wrote:Car is looking tops Cornel. Love the ride height on those wheels. What paint did you use to spray the gloss-black bits?
Thanks Fly.
My diffuser, wing and mirrors was sprayed by a panel shop which is still not on my standard. Kidneys as well but they needed a touch up. So i decided to go with Rust Oleumas i don't have a compressor any more. But I will respray them proper with 2k paint in Dec.
Go Play GTI
GTI Driver
Re: My E90 320d LCi
Postby Go Play GTI » Tue Sep 05, 2017 12:05 pm
Styling
Golf 7 GTI (DSG) :dance:
Golf 6 GTI (Revo) :clap:
Golf 4 GTI :geek:
Citi.com :screwy:
Jetta 2 CLI :popcorn:
Cornel
Re: My E90 320d LCi
Postby Cornel » Wed Jan 10, 2018 2:04 pm
So the buyer that wanted to buy the car before xmas did not come through. So I decided to fit all the goodies. Have 2 more guys that's interested in the car.
Update time
Fitted the Spacers. Fronts is 5mm and rear is 12mm.
My before and after pics looks real shite so I'm posted the rear ones only.
Fronts:
Rears:
Right side rear
Before:
After:
Left side rear
Before:
I also fitted the 4 boost housing seals on the boos pipes. I did not take any pics of that.
The came the fun part. Fitting meth to a BMW is moer baie work!
I went for a Universal Cool Boost Stage 2 Progressive kit. We wanted to play around with the nozzles to see what will work the best.
Opped of a CB5 nozzle in the end.
This is where I wanted my bottle and pump to be.
So we decided to get a Lion and some ply wood.
So it ended up looking like this
Next up was to get the meth line all the way to the engine bay. So we stripped all the panels at the bottom of the car. Removed the front bumper to get to the cooler.
And you'll need something cold to help you focus.
Tapped the meth into the cold side on the cooler
Tapped for boost into the hot side of the cooler.
Then we installed the non-return valve and the fault switch.
Vacuum line. Note its red in most of the pics. On the first run without meth the line popped off, so we took some cable ties as we could not found small enough clamps. Second try the line burst. So we bought a new line(blue one from XXX Centurion).
[hr]
Next up was all the wires. We needed to check what wires needs to stay at the back and which of them needs to go to the front.
All tucked away
Sticked down with double sided tape till I can make up my mind where I want to put it.
Also have a on/off switch.
After everything was sorted on the car, we took it for a run without meth to check that everything is fine. After the two fail attempts it was time to open up the meth kit. Testing was done with water only.
Intake temps managed to drop from 40 degrees to 34 degrees in just 2 gears. So i was very happy as this was the main reason I went with a meth kit.
Before that run
After the run
And then my mate fulled her up and gave me some spare meth
We went to the dyno as well. Managed to gain 9wkw and 40nm with the meth turned on on the second run(no time to adapt)
I also did a service on the car. The following was changed:
5.2l Liqui Moly 4100 Oil
Oil Filter
Fuel Filter
Cabin Filter
Air Filter
Wipers.
Keithan did the stage 1 gearbox flash on Friday as well.
Now time for Stage 2 or 3 with new update file.
Thanks to all that helped me with the car! Really appreciated it
fly
Newbie
Re: My E90 320d LCi
Postby fly » Wed Jan 10, 2018 6:15 pm
Coming along very nice indeed
frozen
K04 GTi
Re: My E90 320d LCi
Postby frozen » Thu Jan 11, 2018 11:19 am
Nice going Cornel
Cornel
Re: My E90 320d LCi
Postby Cornel » Fri Jan 12, 2018 7:58 am
Thanks guys.
bully
Re: My E90 320d LCi
Postby bully » Fri Jan 12, 2018 8:04 am
Nice mater!
Hairdresser car
12.3 Dragwars 2017
252wkw
UCBRacing Fuelled
Return to “Members Gallery”
Users browsing this forum: No registered users and 5 guests
