Audi A3 K04 showcasing APEC Tuned quality
APEC South Africa
Moderator: Hotdubz
Hotdubz
Postby Hotdubz » Fri Dec 01, 2017 5:49 am
Meet the newest member to our APEC Tuned family. The car's previous tune from another tuning house just wasn't cutting it. APEC Tuned worked it's magic and the results speak for themselves!
The previous tune was 208kw and 437nm. With it's current custom APEC Tuned software the car now pushes 230kw and 509nm ATW! The only thing changed on the car was the tune, no hardware mods were done.
The power runs were done at #KAR using 95 pump fuel only.
#APEC #APECTuned #PerformancePerfected
Sent from my SM-G930F using Tapatalk
bully
Re: Audi A3 K04 showcasing APEC Tuned quality
Postby bully » Fri Dec 01, 2017 6:04 am
Lekker. That's quite strong on pump fuel.
Hairdresser car
12.3 Dragwars 2017
252wkw
UCBRacing Fuelled
Hotdubz
Postby Hotdubz » Fri Dec 01, 2017 7:17 am
Thanks man
Mod list on the car is as follows
K04
Full exhaust
Downpipe
Intake
Actuator
Throttle and discharge pipe
Intercooler and WMI still need to be done. The clutch is also on its way out so we lost a little power there.
We'll keep this updated as the car progresses.
MSBGTI
Postby MSBGTI » Fri Dec 01, 2017 8:46 am
Does the car have hpfp?
Figures are very good.
Saw these clutches get shaky near 500nm
Do you have a full graph pic?
Cur: 2012 MK6 GTI ED35
2015 BMW M135i F21
2003 Citi Golf 1.4
2011 BMW 135i DCT.AR 4"Downpipe, PPK2
2012 MK6GTI, 308WHP/230WKW@Stealth Stealth2
2009 MKVI GTI DSG. REVO 2
Hotdubz
Re: RE: Re: Audi A3 K04 showcasing APEC Tuned quality
Postby Hotdubz » Mon Dec 04, 2017 11:45 am
MSBGTI wrote:Does the car have hpfp?
Thanks bud
The car does not have a hpfp. Here's a pic of the graph, you can see clutch acting up on the run. Once the clutch is sorted the graph with smoothen out nicely.
SO NAWTY-ZN
Postby SO NAWTY-ZN » Tue Feb 06, 2018 1:45 pm
so this A3 is running stock injectors and fuel pump and is pushing 230kw?
Current MkV GTi
BMW E36 (4.3Lt LT1 Corvette motor Bi-turbo)
Ex
Astra 200ie 16V Turbo
MkIII Golf VR6 (Tuned by JanSpeed)
Kadett 180is 16V
MkIII Jetta VR6 (Tuned by JanSpeed)
MkI CTi 8V
Astra 160ie
Hotdubz
Postby Hotdubz » Mon Feb 12, 2018 6:56 pm
SO NAWTY-ZN wrote:so this A3 is running stock injectors and fuel pump and is pushing 230kw?
That is correct. It has the EA888 motor, the OEM pump and injectors don't need to be changed.
kesh-29
Postby kesh-29 » Fri Mar 02, 2018 7:12 am
That's a big difference in power.
kesh-29
Postby kesh-29 » Fri Mar 02, 2018 7:13 am
Great work. :salut:
Return to “APEC South Africa”
Users browsing this forum: No registered users and 6 guests
