APR 2+ Golf 5 DSG
Performance Software for VW, Audi, Seat and Porsche , Downpipes, Exhausts, Engine Rebuilds
Moderator: raisin
Wazza
APR 2+ Golf 5 DSG
Postby Wazza » Mon Feb 18, 2013 2:37 pm
Hi Guys
Just wondering what should a 2+ APR G5 DSG make with the following mods
EVOMS Intake
DP
Autotech HPFP Internals
BSH Throttle intake
G6 Intercooler
and obviously the APR stg 2+ map with the cruise control switch between different octanes
On straight 95 octane
Obviously i know that exact figures would vary , but are we talking coparable to REVO or other software vendors here or not
oh ja and these figures would be up in JHB
Please any input here is welcome just wanna get a realistic figure or goal , i feel it should be comparable to other 2+ maps from other vendors ???
cheers
Wazza
G5 DSG
Rabbit222
Re: APR 2+ Golf 5 DSG
Postby Rabbit222 » Mon Feb 18, 2013 3:22 pm
Realistic figures are around 160-165 ATW
Wazza
Postby Wazza » Mon Feb 18, 2013 4:38 pm
Rabbit222 wrote:Realistic figures are around 160-165 ATW
Thanks Mr Mooloo
And that would be mods mentioned and 95 only , No WMI or OB correct?
G5 DSG
Porra46
Fanbooi
Postby Porra46 » Mon Feb 18, 2013 4:58 pm
Hey Wazza!!
Long time bud!
Here is a guide I saw on APR's website...
280 HP is 208kw... Seems a bit optimistic to me but think that is the 98 octane program... Also remember that SA has very poor fuels... I think a healthy G5 will do 180 - 190 flywheel kw (about 160+ wkw like Shaun said)
I think both APR and REVO are very similar in power figures. REVO is known for making power earlier in the rev range while APR are known for making it higher up... Got a friend with a G6 GTI here on REVO stage 1 and that thing feels between robots. So I guess it boils down to preferance and the service you will receive from your tuner.
2012 Candy White Golf 6 R DSG - APR Stage 3
460BHP/344Kw and 608Nm
11.9s 1/4 mile @ Tarlton - Dragwars 2015
Wazza
Postby Wazza » Tue Feb 19, 2013 12:33 pm
Porra46 wrote:Hey Wazza!!
Long time bud!
Hey Bud
Ja long time man
I also saw the projected powers figures on APR's website , very optimistic man
G5 DSG
Wazza
Postby Wazza » Tue Feb 19, 2013 12:35 pm
Ok So last night i checked for errors and got this
1 Fault Found
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 123054 km
Time Indication: 0
Date: 2000.00.00
Time: 03:18:26
Freeze Frame
RPM: 5116 /min
Load: 80.4 %
Speed: 100.0 km/h
Temperature: 96.0░C
Temperature: 44.0░C
Absolute Pres.: 820.0 mbar
Voltage: 13.716 V
Readiness: 0000 0001
I cleared it but it just comes back
so thats maybe why the car feels down
G5 DSG
Rabbit222
Postby Rabbit222 » Tue Feb 19, 2013 1:39 pm
Here you go:
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Turbocharger faulty
Diverter Valve faulty
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
Check Turbocharger
Check Diverter Valve
Special Notes
When found in 2.0l TFSI:
Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
RoW vehicles see: TPI 2016331 for details.
NAR vehicles see: TSB 01-07-70 or 2013392 for details.
When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: Crankcase Breather Valve
If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):
Verify the mechanical part of the Exhaust Valve Control Module (J883) is not siezed or binding.
Return to “Experience Performance/APR Durban”
Users browsing this forum: Bing [Bot] and 2 guests
