Can someone please explain the differences between 2 and 2+ please , I understand you need the HPFP for 2+
but how much of an improvement is there over 2
also can somebody explain to me about the different octane maps are these the same as stg1,2 and 2+ ??
is stg 2+ another name for 100octane map ?
can you run stg2+ on 95 pump fuel?
Also is it possible to use the cruise control to switch between stock , 2 and 2+ , like if i have the HPFP fitted will it break something if a switch to stock then ?
thanks guys
