KO4 DYNO FIGURES FEEDBACK
For all Stealth Tuned related queries and specials
Moderators: Red Devil, GTIV
EXOPELGTILOVER
Postby EXOPELGTILOVER » Mon Jul 24, 2017 11:51 am
Hey guys
i did a ko4 conversion on my golf 6 gti.i was hoping to get some feedback as to whether my figures are within spec.
i know not all cars and setups are the same but am i wrong in thinking that my torque figure should be a bit higher?
i went straight from stock to ko4 so i dont have any previous figures to compare to.
my set up as follows
ko4 hybrid turbo
apr cooler
water meth kit
76mm downpipe
cat back exhaust
r8 coils
forge actuator
forge dumpvalve
intake pipe
throttle pipe
Neuspeed pulley
runs were done on stealth pump file with octane booster and meth
figures on flywheel as per usual in cape town :grin:
252KW 492NM
EXOPELGTILOVER
Re: KO4 DYNO FIGURES FEEDBACK
Postby EXOPELGTILOVER » Mon Jul 24, 2017 11:53 am
dont know how to load images for dyno sheet :facepalm: :grin:
EXOPELGTILOVER
Postby EXOPELGTILOVER » Mon Jul 24, 2017 12:32 pm
s3 Freak
Postby s3 Freak » Mon Jul 24, 2017 5:09 pm
Should be able to push the hybrid more...
2009 G5 GTI DSG - FR&R Tuned
12.7 @ DragWars17
12.6 @ TunerWars18 Round 1 :transform:
s3 Freak
Postby s3 Freak » Mon Jul 24, 2017 5:12 pm
EXOPELGTILOVER wrote:https://postimg.org/image/ogg4s7dl7/
hope this will do ;)
12.7 @ DragWars17
EXOPELGTILOVER
Postby EXOPELGTILOVER » Mon Jul 24, 2017 7:50 pm
s3 Freak wrote:Should be able to push the hybrid more...
thats what i was thinking.....if i look at some of the other stealth ko4 gti's on this dyno most if not all have made more than
i have an some with less hardware and on straight pump FUEL no OB :facepalm:
PS:thanks for loading the dyno sheet :salut:
EXOPELGTILOVER
Postby EXOPELGTILOVER » Mon Jul 24, 2017 7:55 pm
hoping some of the stealth ko4 guys can give some input :)
MLGCUP177
Postby MLGCUP177 » Mon Jul 24, 2017 9:53 pm
Is that flywheel power?
If so could be higher speak to your tuner to give stronger file or check hardware may need ebc and some more octane for a more aggressive file
current Golf VI R BT 10.7s at 207km at Tarlton Drag wars 2019 Ultimate performance tuned
MLGCUP177
Postby MLGCUP177 » Mon Jul 24, 2017 9:54 pm
If so could be higher, speak to your tuner to give a stronger file or check hardware may need ebc and some more octane for a more aggressive file.
EXOPELGTILOVER
Postby EXOPELGTILOVER » Mon Jul 24, 2017 10:11 pm
MLGCUP177 wrote:Is that flywheel power?
yes its flywheel power
Return to “Stealth Tuned”
