Wastegate issue
S@MO 1
Wastegate issue
Postby S@MO 1 » Mon Feb 12, 2018 9:36 am
Hwzit Gents
Need some help please.
I have a Mk4 1.8 BT with ext wastegate. I have the gate hooked up to a Turbo Control valve and the valve to the boost controller.
When i switch the valve on to turn up the boost, the gate opens and stays open, therefore no boost, when i switch the car and the valve off, the gate closes. Car runs fine on low boost.
Any ideas?
Thank you
Samo
Mk4 1.8T - 203wkw/305Nm @ 0.9 bar
s3 Freak
Re: Wastegate issue
Postby s3 Freak » Wed Feb 14, 2018 2:53 pm
Have you tried connecting the Boost controller directly to the Wastegate and boost source?
2009 G5 GTI DSG - FR&R Tuned
12.7 @ DragWars17
12.6 @ TunerWars18 Round 1 :transform:
S@MO 1
Re: Wastegate issue
Postby S@MO 1 » Fri Feb 16, 2018 8:31 am
Thanks for your reply, i'll try this on saturday, only work on the car on weekends.
Going to check the wastegate spring as well.
Cheers
Users browsing this forum: Spud and 2 guests
