VCDS Windows 10 help!!
Need technical help or advice? This is the place for you.
migz10
Postby migz10 » Fri Jan 26, 2018 1:01 pm
Hi guys as per topic states i need help with opening this program.
I have used this plenty in the past with no issues at all.
Im running windows 10 on my laptop and recently it updated and ever since, VCDS just does not want to open.
I have tested it on a different pc and works just fine.
Ive even reset my laptop and still nothing.
Ive tried opening it up as administrator and all that happens is the box saying "please wait" disappears.
Sometimes a box pops and says ok and exit.
Any suggestions would be grateful.
Thanx. :salut:
White MK7 GTI PP with JB4, ROGUE XZORST, VWR R600 and some make up. :afro:
alexdekoker
GTI Driver
Re: VCDS Windows 10 help!!
Postby alexdekoker » Fri Jan 26, 2018 1:09 pm
Try compatibility mode?
Current: Golf 6 GTi Edition 35 Revo Stage 2
Ex: 1.6 Polo Comfortline (9n3)
migz10
Postby migz10 » Sat Feb 03, 2018 7:45 am
Tried all the compatibilities and no luck. Thanks for the suggestion though.
Sent from my SM-G935F using Tapatalk
SamGTI
GTI Driver
Postby SamGTI » Sat Feb 17, 2018 8:53 pm
Which version do you have installed? I'm having similar issues with my VAS5954A. Apparently the software I got with the device is too old to run on windows 10, so I'm now forced to download the latest version off the net which is around +11gb :facepalm:
You should try downloading a later version... 'Im sure a newer version would resolve the bug issues you're having :thumb:
Ex. Toyota Sprinter GLS Exec. (1600 SOHC throttle screamer) :afro:
Ex. Honda Ballade B20 Vtec (The Buddyclub town bicycle revving 4 Days) :troll:
Ex - Golf 5 GTI DSG (Mo boost, Mo problems) :facepalm:
Current - Golf 7 GTI (DP+ Intake)
migz10
Postby migz10 » Tue Feb 20, 2018 9:08 pm
SamGTI wrote:Which version do you have installed? I'm having similar issues with my VAS5954A. Apparently the software I got with the device is too old to run on windows 10, so I'm now forced to download the latest version off the net which is around +11gb :facepalm:
Bud I'm running v16.8....yea will most probably have to get the new V17....
Return to “The Garage”
Users browsing this forum: No registered users and 7 guests
