MK7 Golf VCDS tweaks
ashenchowthee
Re: MK7 Golf VCDS tweaks
Postby ashenchowthee » Fri Mar 04, 2016 7:02 pm
#offtopic Have my VCDS on order! Excitedness!
Sent from my GT-I9195 using Tapatalk
migz10
Postby migz10 » Tue Mar 29, 2016 7:54 pm
Im based in centurion and i happen to have a cable, so if anyone looking for some tweaks let me know, i dont mind helping out a fellow member!
White MK7 GTI PP with JB4, ROGUE XZORST, VWR R600 and some make up. :afro:
TiaanPGTI
Postby TiaanPGTI » Wed Jun 22, 2016 2:15 pm
Migz can you do needle sweep on a Q3 2013 model?
Current: Sapphire Black N54 135i
Corsa 1.7DTi Ute
Ex:Kawasaki ER6N- Totaled
Ex: MY10 Subaru WRX STI
Ex: Candy white 9n3 GTI
Ex: Mini cooper S
Ex: Obsidian Black Pearl Subaru WRX STI (Hawk eye)
Redhot
Postby Redhot » Tue Jul 05, 2016 10:47 pm
by migz10 » Tue Mar 29, 2016 8:54 pm
Anyone in Durban willing to show such generosity. I'd be grateful to have some tweaks.
ooh_pee_see
Postby ooh_pee_see » Fri Dec 16, 2016 6:33 pm
I am based in Sandton and have done mine. If anyone needs help just drop me a pm.
Being second is to be the first of the ones who lose.
Shaddow
Postby Shaddow » Fri Dec 16, 2016 11:13 pm
Anyone have the security code to access the ABS module to change the XDS settings?
Sent from my SM-G920F using Tapatalk
2012 Scirocco DSG K04
CPi Tuned!
12.3@184 - Tuner Wars (Nov 2014)
245wkw 564Nm
2008 Audi TTS S-Tronic - Revo 2, DP (12.9 @ 178 - Tarlton S2S)
2008 Golf 5 GTI DSG - K04 APR Tuned (13.6 @ 175, street tyres - Tarlton S2S)
s3 Freak
Postby s3 Freak » Sat Dec 17, 2016 7:12 am
Shaddow wrote:Anyone have the security code to access the ABS module to change the XDS settings?
40168?
2009 G5 GTI DSG - FR&R Tuned
12.7 @ DragWars17
12.6 @ TunerWars18 Round 1 :transform:
ooh_pee_see
Postby ooh_pee_see » Sat Dec 17, 2016 7:47 am
The code is
20103
Sent from my iPhone using Tapatalk
Shaddow
Postby Shaddow » Sat Dec 17, 2016 10:08 pm
Thanks gents... will try them out and see which one works. Appreciated!
CPi Tuned!
245wkw 564Nm
Sean10
Postby Sean10 » Thu Jan 26, 2017 7:17 am
PDF_27 wrote:Alternating tail light indicator mod
Select -> 9 Central Electronics -> Security Access -> 31347
Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A16:
Set = Blinken lins Dunkelphase. (Default is:Blinken Links Hellphase)
Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A17:
Set = Blinken rechts Dunkelphase. (Default is: Blinken rechts Hellphase)
hi
will this work on the TSi as well?
Users browsing this forum: No registered users and 4 guests
