MK7 Golf VCDS tweaks
MJP
Site Admin
Postby MJP » Tue Mar 04, 2014 6:06 am
Please add any if you find. If you have an OEM VAG cable version 12.12 is the latest version.
here is a some of the ones I found
Check the amount of fuel in your car
For those that want to enable this:
Select [17] Instruments
Long Coding - (Function 07)
Go to Byte 10
Enable bit 4
Disable Seatbelt Warning
Select STG 17 (instruments)
Adaptation Channels -> function 10
Select disable seatbelt warning (Gurtwarner deaktivieren)
change to "yes" (default: none)
Display battery charge level or SOC (state of Charge).
Enter [17] Instruments, then go to adaptation channels,scroll down until you see Battery Charge and simply change it in the new value drop down to "active" and it's done
Rain closing
Go to [09] Central Electronics
Go to Secuity Access and enter 31347
Go to adaptation channels and set the following:
(15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
(16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
(28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) - Set to Active (enables the menu in the ifotainment screen).
Alarm beep
Adaptation channels, and you are looking for:
(1)-Acknowledgement Signals -Akustische Rueckmeldung entriegen (un-lock acoustic feedback)
(2)-Acknowledgement Signals -Akustische Rueckmeldung verriegeln (lock acoustic feedback)
Set one or both to on if you wish.
Then set the following to "on"
(7)-Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung (Acoustic lock menu)
This enables a menu setting in the "car" settings, "Locking" menu of the infotainment screen to set alarm chirp on or off when locking /unlocking the car and have the option to switch it on or off from the head unit.
Staging aka needle sweep
Select STG 17 (switchboard)
Coding -> Function 10
Byte 1
Enable bit 0
Check out our webstore for performance upgrades, wheels, suspensions, lighting, accessories and much more...
VWGTiclub Webstore
APR South Africa
Golf 6 R
Re: MK7 Golf VCDS tweaks
Postby Golf 6 R » Tue Mar 04, 2014 8:25 pm
Sorry to go off topic, my apologies, but can you code or bypass the dvd player in a golf 7 to play whilst in motion? It is an oem sat nav unit...
MJP
Site Admin
Postby MJP » Tue Mar 04, 2014 8:33 pm
Golf 6 R wrote:Sorry to go off topic, my apologies, but can you code or bypass the dvd player in a golf 7 to play whilst in motion? It is an oem sat nav unit...
Will check this out for you. We sell RNS units and we install video in motion which does this. I am sure it can be done on the 7 :thumb:
VWGTiclub Webstore
APR South Africa
GTI07
Postby GTI07 » Wed Mar 05, 2014 1:57 pm
There's a ton of info in the below thread. Time to list each one individually here though.
http://www.golfgtiforum.co.uk/index.php?topic=260248.0
Current
8v RS3 Sportback
1990 MK1 Cabriolet
2015 MK 7 .:R
2005 Polo Hatch
1984 MK1 GX - Bagged
2013 MK 7 GTI DSG
Golf 4 V6 4motion
1982 Mk1 GTS
2007 Golf 5 GTI - K04
DRS
Postby DRS » Thu May 15, 2014 5:35 am
I found this. Not sure it it works.
Sound actuator
Goto
A9 Struct. Borne Sound
Adaptation 10
Select "Channel of structure borne sound actuator" (only one)
Std value 100% Change to the value you want, stored in %
Use suggested code for change approval.
MJP
Site Admin
Postby MJP » Wed Oct 15, 2014 9:21 am
Enable fuel amount to show on MFD
Go to Byte 10
Enable bit 4
Once complete, it should look like this:
Disable Stop/Start
There a currently a couple of ways to fool the start system in to not activating.
By changing temperature conditions:
Go to [19] CAN-Gateway
Go to Adaptation Channels
Change the following entries:
"Start/Stopp AußentemperaturVorgabe-MaximaleTemperatur" from -50 to 50
"Start/Stopp AußentemperaturVorgabe-MinimaleTemperatur" from -50 to 50
By changing minimum battery charge:
Start_stop_voltage_limit from 7.6v to 12v
VWGTiclub Webstore
APR South Africa
Yugz
Postby Yugz » Wed Dec 09, 2015 8:25 am
Hello..
Is there a VCD for enabling the PDC graphic on the display... The one that shows the vehicle with warning lines.
This is for a 7 GTI.
Thanks
Yugz
Golf 7 GTI DSG
JB4 - Full Exhaust - Meth - IS38
TeamMAD Tuned :clap:
13.0 - 183.7km Exit Speed with Full Street Gear @ Tarlton Street2Strip
IC3KING
Postby IC3KING » Thu Dec 10, 2015 8:53 am
Exhaust Flapper Mod for Golf 7 R only
Go to Engine Module
Click Long Coding Helper
Select Byte 9
You will see Bit 2 says Exhaust Flaps Installed and the Check box Ticked.
Untick the Box, click Save/ Do it.
Disconnect, then start your car and Enjoy :)
2016 Golf 7R
PDF_27
Postby PDF_27 » Thu Dec 10, 2015 10:02 am
Alternating tail light indicator mod
Select -> 9 Central Electronics -> Security Access -> 31347
Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A16:
Set = Blinken lins Dunkelphase. (Default is:Blinken Links Hellphase)
Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A17:
Set = Blinken rechts Dunkelphase. (Default is: Blinken rechts Hellphase)
IC3KING
Postby IC3KING » Thu Dec 10, 2015 10:14 am
Thanks PDF_27, was looking for that Tweak.
Not that clued up on VCDS though. When selecting the inner light or outer light should the code next to it be A17 and A16?
As some other forums say select C9
2016 Golf 7R
Users browsing this forum: No registered users and 7 guests
