Change Cam follower
GturboI
Re: Change Cam follower
Postby GturboI » Sun Feb 16, 2014 10:06 am
I took mine to Mclaren auto in Durban north, they got a special at the moment R800 supply and fit
Sent from my iPhone using Tapatalk
Trigger
Postby Trigger » Tue Feb 18, 2014 7:53 am
Thanks for this MJP. I used the DIY and changed mine :afro:
BMW E46 ///M3 SMG Laguna Seca
BMW E53 X5 3.0D Motorsport
Citroen DS3 Sportspack
TyronG6
Postby TyronG6 » Tue Mar 11, 2014 12:38 pm
Trigger wrote:Thanks for this MJP. I used the DIY and changed mine :afro:
How was the damage on the old 1?
Ex :
Mk7 R
MK6 R
MK6 GTi
MK5 GTi
Trigger
Postby Trigger » Tue Mar 11, 2014 3:48 pm
It didn't look damaged bud.
The centre of it was clean silverish
Shafieko
Postby Shafieko » Thu Apr 23, 2015 1:33 pm
Great thread
at what periods should the follower be changed
2006 MKV GTi - Downpipe + Unichip
g10
Postby g10 » Tue Jan 10, 2017 3:52 pm
I checked mine every 10 000kms, I replaced mine 2 times over 4 services. Now with the upgraded fuel pump, I guess it wouldn't hurt to check it every 5 000kms? I stand to be corrected but I rather be safe, it is so easy to check it yourself as long as you have the right tools.
08 Seat Leon FR
FR & R Custom Tuned, IHI Turbo, Vortex Performance HPFP
shellyb
Postby shellyb » Fri Apr 14, 2017 1:48 pm
hi guys im quite new to this.... I have a 2005 gti axx and sounds like a diesel when it's at idle... rpms are not intermittent and cars idle does change when pulling out dip stick at idle witch means pcv valve still in working order I stand corrected..... changed oil to castrol edge 5w40.... when car drives just about over 7000rpm the noise goes away... I haven't checked cam follower as I'm not sure if that could be the problem but have the replacement part... I've also checked out some other posts online and said there cold be a leak on down pipe..... any advise?
Sent from my SM-G935F using Tapatalk
Users browsing this forum: No registered users and 10 guests
