VCDS (VAG.com) settings
MJP
Site Admin
Postby MJP » Fri Aug 03, 2012 10:51 am
Guys, thought it would be nice to post any mods that you can/have done via VCDS. We can make it a sticky for those wanting to do these mods.
Xenon lights level
Using VCDS(vag-com)
Make sure you're on a level surface.
Click Select Controller
Go to 55 - Xenon Range
Go to Basic Settings - 04
Then in the drop down list, select the adaptation/adjustment option (its the only one in the drop down).
Then click the ON/OFF/NEXT button.
XDS (Diff settings)Pimped from an international forum.
n VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
I tasted this one and finally locked it in value 2. I think the brake pedal and the whole system are more sensitive. My car was not braking any better but I did not have to push down the brake pedal as low as before and as hard as before to start braking.
Channel 36 XDS
1-weak
2-strong
Channel 54 DSR
0-strong (stock setting)
1-center
2-weak
Channel 58 Hill Hold Assist
0-normal
1-early (start with low RPM's)
2-late (start with high RPM's and slipping clutch)
Channel 89 ASR
Two settings
1-on (stock setting)
2-off
I tried to turn it off, the new setting was saved but after I disconnected and connected the vag com cable to check it out it was set back to value 1-“on” . So, I think it's not possible to turn it off with the VCDS software.
Channel 90 ESP
Two settings
2-off
The same thing as with the ASR. I was able to turn it off but it was set back to “on” setting after disconnecting and connecting the vag com cable.
Channel 91 Automatic, ESP switch on, Speed
There are 4 boxes 1-Automatic, 2-ESP switch on, 3-Speed, 4-Deactivated (this setting can be changed)
Boxes 1 to 3 describe probably condition which are already programmed
Two settings
0-Deactivated (stock setting)
1-Enabled
Check out our webstore for performance upgrades, wheels, suspensions, lighting, accessories and much more...
VWGTiclub Webstore
APR South Africa
MJP
Site Admin
Re: VCDS (VAG.com) settings
Postby MJP » Fri Aug 03, 2012 10:56 am
Needle Sweep
You need an "H" type cluster or else it won't work. This will not work on MKV GTis
In Vag Com:
Address 17 – Instruments
Adaptation 10
Select “Staging” from the drop down list
Select “Active” from the drop down list
Save the changes
Done!
VWGTiclub Webstore
APR South Africa
Ian23
Postby Ian23 » Fri Aug 03, 2012 10:59 am
Awesome post. Please sticky?@
How An Engine Works... Exhaust gases go into the turbocharger and spin it, witchcraft happens, sign posts fly by at light speed, the girl in your passenger seat screams!
MJP
Site Admin
Postby MJP » Fri Aug 03, 2012 11:16 am
Guys, I have uploaded a great list of VCDS mods. You can turn of seatbelt warnings, enable alarm horn etc. Check it out.
VCDS Mods
VWGTiclub Webstore
APR South Africa
Sean_G6
Postby Sean_G6 » Fri Aug 03, 2012 1:15 pm
Thanks Mal , just need a Vagcom now lol
Titleists
Postby Titleists » Fri Aug 03, 2012 3:06 pm
I can do it. R150 for vcds changes.
VCDS Changes done by me for a minimal fee
Ex:'13 Roc R. Revo 1
'11 Revo 2 Golf 6 GTI.
tfsi
Postby tfsi » Fri Aug 03, 2012 4:30 pm
Titleists wrote:I can do it. R150 for vcds changes.
capitalist. :D
ryanrich
Postby ryanrich » Fri Aug 03, 2012 7:26 pm
I do it for free in CPT... Just meet people and for the passion. :D
Have done many cars already...
tfsi
Postby tfsi » Fri Aug 03, 2012 8:49 pm
ryanrich wrote:I do it for free in CPT... Just meet people and for the passion. :D
lol, the difference between joburg and cape town! :D
Inferno
Postby Inferno » Sun Aug 05, 2012 7:31 pm
Thanks mal.
Finally switched on my alarm horn when locking with the key now!
Users browsing this forum: No registered users and 4 guests
