Biggest Rant Possible - Turbo Direct SA
How was the service that you received...this is the place to rave or rant...
Shaddow
Re: Biggest Rant Possible - Turbo Direct SA
Postby Shaddow » Fri Jul 14, 2017 10:40 am
Tell them that you're happy to return the parts, as long as they pay for your trusted mechanic to strip and remove the extra parts that THEY gave you!
Sent from my SM-G935F using Tapatalk
2012 Scirocco DSG K04
CPi Tuned!
12.3@184 - Tuner Wars (Nov 2014)
245wkw 564Nm
2008 Audi TTS S-Tronic - Revo 2, DP (12.9 @ 178 - Tarlton S2S)
2008 Golf 5 GTI DSG - K04 APR Tuned (13.6 @ 175, street tyres - Tarlton S2S)
MLGCUP177
Postby MLGCUP177 » Fri Jul 14, 2017 11:13 am
terrible better to import from ATP
current Golf VI R BT 11.2s at 203km at Tarlton tuner wars May 19
Germinator
Postby Germinator » Sun Jul 16, 2017 3:55 pm
teamx wrote:
Rommies wrote:thanks for the heads up. any alternative companies for turbo repairs?
Fastec, Gaby is an absolute machine. They're based in Germiston
+1000
Class workmanship coupled with brilliant service. You call Gabby and he will always answer, if not - he will call you back even if he doesn't know your number. A real gentleman :thumb:
2011 Golf 6 GTI
KO4H - DSG
FR&R Tuned
300wkw @ FR&R
308wkw @ Precision Race
12.0 Dragwars 2017
12.0 Tuner Warz 2017
RN_MK7GTI
Postby RN_MK7GTI » Mon Jul 31, 2017 1:24 pm
+1000
My friend sent his turbo to Gabby (a GTB2260) because the Turbo had a whine to it. Gabby called my friend three times over the course of turbo repair and fitting a new billet turbine to convert the turbo to a GTB2262. Every time Gabby called him they didn't speak for less than 30 min (this is the extent to which he will go to inform his customer about everything going on with the turbo.)
When the turbo arrived this past friday everything was included in the courier box even the old bolts where in a small bag. Balancing sheet also included.
Gabby does top work on turbos. Big up to him!! :salut:
Current: 2014 Mk7 GTI manual :thumb:
(13.3 @ 180km/h Dragwars2017) street tires
(231.8km/h @ ODI)
Is38 upgrade
APR Is38 Tune
APR Carbonio
TMSS DP
GFB DV+
Ex: 2010 Citi xcite
Return to “Rants and Raves”
