Some 8V RS3 Tuning
Ultimate Performance
Moderator: Deamox1fy
MLGCUP177
Re: Some 8V RS3 Tuning
Postby MLGCUP177 » Fri Jul 29, 2016 11:10 am
I wonder if the new rs3 will have the same issues with the pistons being a weak point?
is the motor and turbo the same as the 8P RS3?
current Golf VI R BT 11.2s at 203km at Tarlton tuner wars May 19
NT33333
Re: RE: Re: Some 8V RS3 Tuning
Postby NT33333 » Thu Aug 25, 2016 11:00 pm
imi007 wrote:[quote="kevin07"]Nice figures, What is the boost now set at on the 300kw file?
Should be 1.5 bar roughly.[/quote]
When is urs coming out to play Imi? Well done Preshen. Looking forward to seeing these beasts on the strip now
Sent from my SM-T805 using Tapatalk
Jacques GTI
Postby Jacques GTI » Tue Aug 30, 2016 7:26 am
MLGCUP177 wrote:I wonder if the new rs3 will have the same issues with the pistons being a weak point?
I would also like to know ?
As far as I can see the 2 motors are identical, I could not find any forum or write up suggesting that they are indeed different.
the only major changes was the boost pressure on the new 8V been more than the 8P, and the fuel pressure (possibly different pump but not sure)
If these engines are indeed the same and uses the same pistons/conrods/crank shafts/injectors etc then I would like to know how the reliability is now on the 8V. if it's fine then is the cases of the 8P a case of bad tuning causing the failures (I know of one RS3 but not sure of tuning house).
2012 Audi RS3
for all your Health & Safety requirement please contact me vanlogj@gmail.com
turbodub
Postby turbodub » Tue Aug 30, 2016 11:33 am
from what i have read there is a totally new 2.5 5 cylinder motor coming out in the updated RS3 in the near future .
MLGCUP177
Postby MLGCUP177 » Tue Aug 30, 2016 12:01 pm
Yes Audi got a new motor in the TTRS I think the turbo and fueling is diff in the current rs3 as if u look the the dyno charts the car makes torque very early in the rpm range no lag at all compared to 8P rs3 with k16 turbo maybe it's a IHI turbo like the 7R in the 8V rs3. I know the old rs3 pulled loads of timing from the factory and responds well to octane so I know of 3 8P rs3s with melted Pistons
imi007
Fanbooi
Postby imi007 » Wed Aug 31, 2016 9:03 am
Motors are identical in the 8P and 8V. Turbos too. Audi have revised their tune and chasis/haldex with the 8V.
The 8P pistons were not an issue. It was the fuelling on these motors. Motor would usually starve for fuel on cylinder 1 or 3, causing them to run lean and pop. From what I understand, they have tried to sort out the fuelling issue with the new RS3 but not sure to what extent.
Current :
REVO 3 Scirocco
241km/h over the 1km - ODI Raceway (08 Sept 2013)
12.5 @ 180km/h Dragwars 2013
12.5 @ 185.8km/h Dragwars Invitational 2013 - 2nd place
Jacques GTI
Postby Jacques GTI » Thu Sep 01, 2016 7:04 am
imi007 wrote:Motors are identical in the 8P and 8V. Turbos too. Audi have revised their tune and chasis/haldex with the 8V.
Yip same Turbo's, found a site that had both engines in detail ... (took some searching :-) ) but the same engine same turbo, boost and fuelling is different. (fuel pressure is different) boost is slightly higher.
So my question is what needs to be done to a 8P to ensure that fuelling is correct surely this cannot be to much work. ?
2012 Audi RS3
Return to “CPI Chiptuning”
