Advice needed : ABF Flywheel
For all performance related upgrades this is the forum to discuss and get information from....
S@MO 1
GTI Driver
Postby S@MO 1 » Mon Nov 13, 2017 12:43 pm
Hwzit gents
Need some assistance please.
I fitted an ABF Fly to my 1.8t Golf 4 and now the starter wont line up.
Any1 had this issue and how did you resolve it?
Thanks
Samo
Mk4 1.8T - 203wkw/305Nm @ 0.9 bar
gti08
Re: Advice needed : ABF Flywheel
Postby gti08 » Tue Nov 14, 2017 8:08 am
only 2 things will cause that problem.
either the flywheel diameter is in correct if it is a conversion you have done or the number teeth on the ring gears are different
14 GTI DSG
gti08
Postby gti08 » Tue Nov 14, 2017 8:14 am
also a height/thickness difference between the 2 flywheels
14 GTI DSG
S@MO 1
GTI Driver
Postby S@MO 1 » Tue Nov 14, 2017 1:47 pm
Thanks for your reply.
Issue resolved, used a TDI starter, now to get through the 1000km 'run in' before i can make some power.
Cheers
gti08
Postby gti08 » Tue Nov 14, 2017 2:41 pm
so there is definitely a difference with depth or teeth on the ring gear
14 GTI DSG
S@MO 1
GTI Driver
Postby S@MO 1 » Wed Nov 15, 2017 8:30 am
ring gear is the same, depth was the problem.
Return to “Performance upgrades”
Users browsing this forum: No registered users and 3 guests
